cannot find 'win-OS-upgrade-K9.2000-2-7.exe' in CCO
Answered Question
Aug 9th, 2007
anyboby know the location to download 'win-OS-upgrade-K9.2000-2-7.exe' in CCO?
Thanks in advance,
Correct Answer by AJAZ NAWAZ about 9 years 9 months ago
goto Cisco.com and login using your CCO ID. you must have download privilages. in the search field on the home page type:
win-OS-upgrade-K9.2000-2-7.exe - then click the search button.
that should take you onto download confirm page. click on :
Download Software for : win-OS-Upgrade-K9.2000-2-7.exe
please rate the post if it helped.
best regards
Ajaz
Overall Rating: 5 (1 ratings)
Correct Answer
AJAZ NAWAZ Fri, 08/10/2007 - 15:17
  • Silver, 250 points or more
best regards
Ajaz
ondrej_halas Fri, 01/04/2008 - 01:14
Hi All,
because I have to upgrade CCM 3.3(3) to CCM 3.3(5) to... I need file win-OS-upgrade-K9.2000-2-7.exe. But this file really is not on Cisco pages to download. On page/location to download is message: "Error: Session is no longer valid."
Thank you for your answer.
Ondra
