ISDN on CCNA 640-801 Exam
Aug 9th, 2007
Is there any chance of there being a simulation type question on ISDN in the CCNA 640-801 exam ?
I have not had the chance to practice on ISDN equipment, and had only a little practice during Labs.
Also I was wondering whether you would be expected to remember the encoding/framing types and ISDN switch types for the exam, ie.
linecode { ami | b8zs | hdb3 }
framing { sf | esf | crc4 }
isdn switch-type { basic-net3 | ntt | vn3 | basic-5ess | basic-dms100 | etc }
Or will online help via ? be available to display these options after typing the command ?
Overall Rating: 3 (1 ratings)
purohit_810 Fri, 08/10/2007 - 04:39
Yes, You can get help by " ? " using. In simulation.
ISDN simulation comes some time but not frequetaly looks into current database.
If you would take risk you can but if you are going for the exam you should not take chance to miss something.
If you are not prepared well you can postpond your exam on and before 24 hours.
Dharmesh Purohit
purohit_810 Fri, 08/10/2007 - 05:07
Do you have braindumps:
if not go on search the paper no and select testking latest version,You will get simulation from it.
That cisco has in it's database. just see and go for exam.
Dharmesh Purohit
