Dropped Calls to UCCX agents
Aug 9th, 2007
Calls to agents are getting dropped. The MIVR log gives this as an explanation:
3995854: Aug 09 14:02:53.857 EDT %MIVR-SS_TEL-3-CONSULT_FAILED:Consult failed: All Call ids=CallID:3142 MediaId:5243/1 Task:38000006880,Extension=5045,Exception=com.cisco.jtapi.PlatformExceptionImpl: Could not meet post conditions of call.transfer(),Failure reason=transfer gets error CTIERR_UNSPECIFIED=0x0
3995855: Aug 09 14:02:53.857 EDT %MIVR-SS_TEL-3-EXCEPTION:com.cisco.jtapi.PlatformExceptionImpl: Could not meet post conditions of call.transfer()
Any help would be appreciated
lpezj Thu, 08/09/2007 - 23:00
  • Gold, 750 points or more
Have you checked if calls can be transfered from CTI Route Points to CTI Ports and agent extensions?
Check if your partitions/calling search spaces in CallManager allows all the above transfers.
Hope this helps,
Juan Luis
