CSS 115xx and 1115x Telnet issue
Aug 9th, 2007
Hi everyone
I really hope there is a solution to this problem which has been irritating me for years:
When I copy and paste more than a few lines of config into any one of our CSSs (ver 5.00, 7.50, 8.10 all have the problem), some characters get missed, and I get syntax errors back from the device.
This applies to telnet and hyperterminal, whether serial or TCP/IP based, although the symptoms are much worse with TCP/IP.
If I specify a delay of 2000ms between lines and 30ms between characters, the config gets pasted correctly. However, this is taking a lot of time, as we make a lot of changes to the config.
I've tried a few telnet programs (Putty, etc), but they all have the same problem.
Any ideas how I can fix this?
Gilles Dufour Fri, 08/10/2007 - 04:21
this is a CSS restriction and there is no solution to make it work.
You should try to modify your config in a text file and upload the text file into the CSS via ftp.
osiristrading123 Fri, 08/10/2007 - 05:14
Thanks for the reply. I see an option to copy from ftp to startup-config, but not to running-config - how does one achieve this?
Also, does copying to the config overwrite the config, or add to it (as per IOS)?
Gilles Dufour Fri, 08/10/2007 - 06:09
indeed, you can only copy to the startup-config.
What you can do is a 'archive startup-config startup-config', then copy the new config via tftp into startup-config.
Then 'copy startup-config running-config' and if necessary, you can 'restore startup-config' [the old config].
Also, the copy to startup-config is not an ADD. It's a REPLACE.
