NAT
Overall Rating: 3 (1 ratings)
spremkumar Thu, 08/09/2007 - 23:40
  • Red, 2250 points or more
hi
are you planning to extend external access to the new ip range ?
regds
Route_reflector Sun, 08/12/2007 - 20:32
As I understand ur problem, u want to use some private ips as well as some public IPs within the LAN. AM i Right?
Whats ur NAT router? If its Cisco, and if you have correctly defined ur private pool (only with 172.30.7.0/24) it will not affect ur 5.5.5.0 range and you can directly go out with the source ip range of 5.5.5.0/24 . Belive I answered ur question....
Rate if this helps u...
Rgds..
