PAT config
Aug 10th, 2007
Hi guys,
I am trying to start PAT translation
I have a 2600 router with one serial interface (outside) and one fa inte (inside).
There is a switch attached to the fa interface with two hosts.
On the router i have coded whats below:
ip nat pool pula_moja netmask
ip nat inside source list 8 pool pula_moja overload
access-list 8 permit
please help!!!!!
i dont get it i guess!!!
Jon Marshall Fri, 08/10/2007 - 00:37
If you want to use PAT then you don't need a nat pool
ip nat inside source list 8 interface s0/0 overload
int fa0/0
ip nat inside
int s0/0
ip nat outside
bartolc12 Fri, 08/10/2007 - 00:49
how do i specify the addresses?
let's say that my host are -11
my vlan is and my router fas ethernet interface is
Should i just change the addresses of my hosts, change the access list and nat will translate my host addresses into the fast ethernet address and vice versa?
Jon Marshall Fri, 08/10/2007 - 04:03
Sorry i realised the answer i gave before didn't quite fit what you were asking. The confusion comes from the fact that you are trying to do PAT but you are mapping 2 inside hosts to 2 natted addresses which isn't really PAT.
Do you want to do PAT or nat ie.
2 hosts on the inside and 2 addresses to NAT to could be done as follows
ip nat inside source static
You original config should work - what are you seeing when you test it ?
Route_reflector Sun, 08/12/2007 - 20:42
Seems ur confs are ok. Have u configured "IP nat inside" at ur Fas side and "IP nat outside" at Serial inteface ??
