Reg:fxo to fxs
Aug 10th, 2007
Dear sir,
i want fxo to fxs configuration and my problem is in 2800 seriies fxo i connected my epbx line and and in remote side fxs i connected anolog phones now iwant through my epbx i want any number
i diled it should go through the fxo call should land in fxs port.
how can i configure the router.plz give me detailed config.
regards
srinivas.D
9246571397
spremkumar Fri, 08/10/2007 - 02:14
  • Red, 2250 points or more
hi srini
You need to have both pots/voip config on both the ends to recieve as well as initiate calls from both the ends.
You can refer the below config to get started.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a0080089516.html#1028743
you can get back here if you still need clarifications on the same..
regds
