Applying Route-Maps
Aug 10th, 2007
Am trying to apply a route-map to a vlan interface using the "ip policy route-map" command.
Although I am able to configure this command on the vlan interface, it doesnt actually appear as applied to the interface, when i run "show ip policy"
Can you actually apply a route-map to a VLAN inteface ?
Mark
spremkumar Fri, 08/10/2007 - 03:21
  • Red, 2250 points or more
hi
can you revert with the details about the device in which you are trying the same ?
regds
marksenteza Fri, 08/10/2007 - 03:24
Am configuring a Catalyst 3560 Switch running IOS 12.2.
IP Routing is turned on, and I have a number of vlan interfaces configured on it.
mohammedmahmoud Fri, 08/10/2007 - 03:54
  • Green, 3000 points or more
PBR on 3560 requires sdm template routing "sdm prefer routing", and before all you need IP Services IOS (formerly called the Enhanced Multilayer Image, or EMI).
HTH,
Mohammed Mahmoud.
