graemeporter Fri, 08/10/2007 - 03:15
Hi Moses,
Whenever I've had to do it, I've done (e.g.):
router(conf)#no interface FastEthernet0/0.1
The subinterface is deleted, but you may find that the configuration file still shows that the subinterface is there until you restart the router.
If there's a better, cleaner way of doing this, please let us know as it'd be quite useful.
Hope this helps!
Kind regards
Graeme
Pavel Bykov Fri, 08/10/2007 - 03:49
The cleaner way is the following:
(config)#default interface GigabitEthernet0/0.1
(config)#no interface GigabitEthernet0/0.1
Warning message will still appear, but it is not relevant anymore, since interface will have no configuration.
