4506 SFP SUP ports
Answered Question
Aug 10th, 2007
  • Blue, 1500 points or more
Whats with the sfp gig ports on a SUP V for the 4506s? There are restrictions on their use. I tried using them as uplinks to a fiber riser to a 6513 yesterday and it didnt work.
What is idfferent about the SUP sfp ports from the ones found on a dedicated I/O card??
Correct Answer by thomas.chen about 9 years 9 months ago
On the SupV-10GE, you can use either the TenGig ports or the SFP Gig ports. SFP and 10-Gigabit Ethernet uplink options cannot be used simultaneously. By default, the TenGig ports are enabled, so to use the SFP gig ports, simply use the following command:
hw-module uplink select gigabitethernet
Overall Rating: 5 (1 ratings)
Correct Answer
thomas.chen Thu, 08/16/2007 - 10:40
  • Silver, 250 points or more
lamav Fri, 08/17/2007 - 06:30
Thanks, Thomas
