show Processes cpu equivalent command on 5500 CATOS
visurth130174
what is the command to view current cpu usage..?
mohammedmahmoud
Level 11
Level 11
For CatOS it is "show proc cpu", not processes.
HTH,
Mohammed Mahmoud.
I tried the command sh proc cpu on 5505 switch running catos...but does not give me the output.
i know that the command on catos running supports for 6500s.
It should work , works on all our 5500's . If its a real old sup it might not work or a real old code version .
