WS-X4506-GB-T compatibility with 100FX SFP Modules.
Answered Question
Looking for a compatibility check for 100FX SFP modules in a 4506 switch using the 4506-GB-T interface. Specifically extending distance over MMF. I will be going from the 4506 to 3750's, 3560's, 2960's series switches.
Correct Answer by everestm about 9 years 10 months ago
100FX SFP modules will not work in that line card. The only line card we could get to accept 100FX SFPs was the WS-X4248-FE-SFP module.
Overall Rating: 5 (1 ratings)
Correct Answer
everestm Sat, 08/11/2007 - 16:10
