block by domain name via GUI?
Aug 10th, 2007
Hi guys - duh question.
Trying to block in and out traffic from a domain (super-servers.net, actually.) Want to do it by domain as opposed to IP, under the assumption that these boneheads will shift IP addys frequently.
Went into the ASDM, went to add rule, but it'll only let me do a rule via IP or via interface.
So how do I block a domain?
-jimr
c1001ess n00b
srue Fri, 08/10/2007 - 08:59
you need a 3rd party URL filter software app. NH2 or websense.
or if you have an IOS router in place, you can use policy-maps. there might be other ways, but I don't know them.
class-map match-any url-block
description TEST FOR URL FILTERING
match protocol http host "*super-servers.net"
policy-map url-filter
class url-block
set ip dscp 1
Then create (or add an entry) an ACL to deny any any dscp 1.
apply the ACL, apply the policy map.
http://www.cisco.com/warp/public/63/nbar_acl_codered.shtml
