08-10-2007 07:18 AM
Is there any CardDescr master list like CardType (1.3.6.1.4.1.9.3.6.11.1.2).
Sreeni
08-10-2007 07:50 AM
The MIBs themselves maintain the values for the various enumerations. For cardType, this can be found in the OLD-CISCO-CHASSIS-MIB which can be downloaded from ftp://ftp.cisco.com/pub/mibs/v2/ .
08-10-2007 10:05 PM
I am looking for Card Description which is a text field not an enumeration type.
08-10-2007 10:35 PM
The cardType enumeration map gives you, for example:
pos-16oc3-lr(559)
Some entries in the MIB even have comments that provide a more detailed description:
pos-16oc3-lr(559) -- GSR 16 port OC3 SM long reach POS
However, for the cardDescr object, there is no master reference of all the potential strings.
08-10-2007 10:42 PM
08-10-2007 11:07 PM
And, as I said, there is not a master database of all potential cardDescr values.
08-12-2007 03:43 AM
the OID 1.3.6.1.4.1.9.3.6.11.1(cardTableEntry) status says its deprecated, is there any equivalent OID for the same.
08-12-2007 09:43 AM
The entire OLD-CISCO-CHASSIS-MIB is deprecated. Most devices in newer versions of IOS have started supporting the ENTITY-MIB, and the various Cisco extensions to it. For the cardTable, the majority of objects have equivalents in the entPhysicalTable from the ENTITY-MIB.
08-22-2007 03:13 AM
in the entity-mib, for 7206 router's card name (1.3.6.1.2.1.47.1.1.1.1.13) is null.
Also on 12410, 12406, 12008 routers we are observing the card name (1.3.6.1.2.1.47.1.1.1.1.13) is coming a some integer value.
is there any reason for this.
Sreeni
08-22-2007 08:59 AM
Only the 7206VXRs properly support the ENTITY-MIB. So, this 7206 may require you to use the cardTable from the OLD-CISCO-CHASSIS-MIB still. I'm not certain about the GSRs. This may be a bug.
