Cisco Client VPN - Problem
Aug 10th, 2007
I have a problem with Cisco client.
After VPN connection has been established, all other network connections are terminated and I?m not able to reconnect until after shutting down VPN connection .
Is there a possibility to configure VPN client in such a way that there will be a possibility to simultaneously connect with VPN and ,for instance local SQL Server database?
anith Wed, 08/22/2007 - 04:20
use split tunnuling in ur vpn server
cheers,
Anith
