You can change the message length under Templates/User Templates/VoiceMailUSerTemplate
Then select Edit/Message Settings. The first setting is Maximum Message Length.
You can change the message delete settings at
System Settings/Message Aging Policy.
There you can change how a message is handled after it is deleted.
Please rate if helpful.
