Routers for CCIE voice lab
Chris Deren Sat, 08/11/2007 - 09:06
To setup a 3 site environment you will need 4 routers, one at each site plus a Frame Relay switch. One router we'll need CME/CUE, others need to support GK (you never know how many GK you'll get or which site will have it). The current lab still utilizes 3725, but you get use ISR routers, the only difference will be media resource configuration. If you want to expend your lab you can get another router to simulate PSTN/backbone GK, or depending on what you use for the FR router you can bundle it all into one.
HTH,
Chris
