Port-Channel on Cisco 2851 router
Answered Question
Aug 10th, 2007
Is there an issue with regards to Port-Channel on Cisco 2851 router? I keep running into problems doing this.
Thank you.
Correct Answer by royalblues about 9 years 7 months ago
Routers do not support any type PagP or LACP negotiation and hence make sure that it is disabled.
Have a look at this link for configuring etherchannel between router and switch
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094958.shtml
HTH, rate if it does
Narayan
Overall Rating: 5 (1 ratings)
royalblues Fri, 08/10/2007 - 12:24
  • Green, 3000 points or more
What kind of issues are you facing?
have you configured the etherchannel on the onboard interfaces or on the etherswitch modules?
Can you post sh int portchannel from both router and switch?
Narayan
rickyhadlocon Fri, 08/10/2007 - 12:34
thanks for the quick reply. i have configure the port-channel on the on-board interfaces. for the access switch, i also configured the port-channel to where the two links from the router will connect.
mohammedmahmoud Fri, 08/10/2007 - 12:27
What kind of problems, can you please paste your configuration and describe the problem that you are running through.
[edit] Narayan, sorry :)
BR,
Mohammed Mahmoud.
Andyfweih Mon, 08/13/2007 - 02:53
Dear business partners & valued customers :
I am pleased to enclose it for your reference.
We can give you better price depending on the items and Qty.
Large quantity new & used Cisco and networking products that aren't
included in this catalogue. Feel free to contact us with your
requirements.
50% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-24TS-S
WS-C3560-48TS-S
WS-C3560G-24TS-S
WS-C3560G-48TS-S
WS-C3750-24TS-S
WS-C3750-48TS-S
WS-C3750G-12S-S
WS-C3750G-24TS-S
WS-C3750G-24PS-S
60% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-48TS-E
WS-C3560-24TS-E
WS-C3750G-24T-E
WS-C3750G-24TS-E
WS-C3750G-24PS-E
WS-C3750G-48TS-E
WS-C3750G-48PS-E
Looking forward to receiving your enquiries soon.
Best Regards
Andy Feng
FEDON(INT'L)DEVELOPMENT LTD
MSN:[email protected]
Email:[email protected]
Http://fweih.diytrade.com
