3600 Modules compatible with 3845 router?
Aug 10th, 2007
Dear All,
Right now we are using 3640 router with the
following modules
1.PRI2CE1B
2.PRI1CE1U
3.2FE2W with WIC2T
4.SERIAL 8A/S
We are in replacing the router with 3845.
If we replace the router what about the modules whether can we use exsisiting moduels with 3800 or not.
Please help me before the router upgrade.
swamy
balajitvk Fri, 08/10/2007 - 23:15
  • Silver, 250 points or more
Pls. do provide the exact modle number of NMs.
If NM-2CE1, NM-1CE1U then i don't see the support.
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_installation_guide_chapter09186a008007c8c4.html
3845 will support 2FE2W with WIC2T.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a00801aa71c.html
SERIAL 8A/S - Cisco 3845 will support NM-8A/S.
Rate if it does,
Rgs,
arumugasamy Sat, 08/11/2007 - 22:01
Thanks balaji,
Let me update you once i got the details from the customer.
Swamy
arumugasamy Mon, 08/13/2007 - 07:22
Dear Bala,
I am waiting for the customer's reply
swamy
royalblues Sat, 08/11/2007 - 13:06
  • Green, 3000 points or more
Swamy,
The PRI2 CE1B & U are not supported on the 38XX series routers. Rest of the modules should be supported
Have a look at the Cisco router guide to check out the support of the modules
http://www.cisco.com/application/pdf/en/us/guest/products/ps5855/c1031/cdccont_0900aecd8019dc1f.pdf
you can also check out the 38XX data sheet to check the varioud modules supported on the platform
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8016a8e8.html
HTH, rate if it does
Narayan
arumugasamy Sat, 08/11/2007 - 22:04
Could you provide me the part number of all the modules of 3662 matching the 3800 series router.
swamy
Andyfweih Mon, 08/13/2007 - 02:52
Dear business partners & valued customers :
I am pleased to enclose it for your reference.
We can give you better price depending on the items and Qty.
Large quantity new & used Cisco and networking products that aren't
included in this catalogue. Feel free to contact us with your
requirements.
50% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-24TS-S
WS-C3560-48TS-S
WS-C3560G-24TS-S
WS-C3560G-48TS-S
WS-C3750-24TS-S
WS-C3750-48TS-S
WS-C3750G-12S-S
WS-C3750G-24TS-S
WS-C3750G-24PS-S
60% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-48TS-E
WS-C3560-24TS-E
WS-C3750G-24T-E
WS-C3750G-24TS-E
WS-C3750G-24PS-E
WS-C3750G-48TS-E
WS-C3750G-48PS-E
Looking forward to receiving your enquiries soon.
Best Regards
Andy Feng
FEDON(INT'L)DEVELOPMENT LTD
MSN:[email protected]
Email:[email protected]
Http://fweih.diytrade.com
