bgp conditional peering
Aug 11th, 2007
hi everyone, i had a question regarding bgp.
Suppose i have 2 routers peering with an ISP ( whether same ISP or 2 different ISP ) lets name these routers RA and RB. i want RB to make a peering session with its ISP if and only if RA fails its bgp session, now u can also assume that RA fails completely or just loses its bgp connection, in either case i want RB to start its own bgp session, so i want to make RB backup of RA in terms of BGP.
how can it be possible
criss_noh Sun, 08/12/2007 - 21:10
yes. that is commonly used. you can have backup line via BGP or have 2 paths likely loadbalancing.
illusion_rox Mon, 08/13/2007 - 00:47
can u kindly tell me that how its possible ? what configuration i have to do ???
royalblues Mon, 08/13/2007 - 01:09
The only way i could think of achieving this is by configuring BGP over loopbacks and making sure that it is reachable only when your primary links come up.
criss_noh Thu, 09/20/2007 - 20:48
that is very simple. you just command maximum-path 2. but please make sure all of BGP best path selection procedure.
router bgp 10
neighbor x.x.x.x remote-as xxxx
maximum-paths 2
etienne.basset Thu, 09/20/2007 - 23:55
i don't know exactly why you want to to this but you should do like this :
then RA set localpref150 on incoming routes,
RB do as path prepend on outgoing routes...
it's more clean than 'conditionnal peering'
criss_noh Sat, 09/22/2007 - 19:23
Dear etienne,
I guess that he wants to have 2 paths on the same router. this means link redundency vis bgp not router redundency.
