What's the difference of IOS version between 3750-24ts and 3750-12s
Aug 11th, 2007
Hi,all
Today,i upgraded IOS version for my 3750 switches.MY supplier gived me two tar files,one of which is for 3750-24ts and other is for 3750-12s. However,i found the two tar image files are all in same namning and size.To me,there seems no difference.
Could anyone tell me some differences between them,or can i upgrade all my 3750-24ts and 3750-12s switches using one of the two tar image files?
Thanks!
Overall Rating: 5 (1 ratings)
Edison Ortiz Sat, 08/11/2007 - 11:35
  • Hall of Fame,
    Founding Member
You can use the same image on both hardware.
freedream Sat, 08/11/2007 - 19:22
Thanks a lot.
You mean that there is no difference of IOS images for same serial hardwares such as Cisco 3750s,3560s.
Edison Ortiz Sat, 08/11/2007 - 21:47
  • Hall of Fame,
    Founding Member
You can't interchange the IOS image between the 3750 and 3560, but you can download an IOS image for a 3750 and install it on all 3750 models. Same applies for the 3560 family.
