asa SSL VPN (anyconnect) Please help ....
Aug 11th, 2007
Hello !!
I am having some problems with ssl vpn and anyconnect client in asa 5505.
The problem is, when I run the configuration wizard for SSL vpn, I follow the instructions and I type address pool for vpn users, add the anyconnect client, (anyconnect client file is uploaded to asa) and then I come to the portal customization, there I add some http links, so on the end I click the finish.
When I test it I can log in success no problems at all I use https://asa_address so I open the web ssl vpn, BUT when I log in I am only able to se the links in the portal:
"Browse"
"Web Applications"
"Terminal Servers"
I am not able to se my custom added links at all, and also I am not able to see the link Anyconnect even if I added it.
Can someone explain me what the problem is ? something I missed ?
do I need to add the Certificate in order to use anyconnect ?? but this can`t be reason that I can`t see the anyconnect link on the portal.
I also would like to get som useful links where I can see total ASDM 6.0 configuration guide in GUI, I tryed to find but only in cli, not so easy to configure an asa using cli.
Thank You
Best regards
beth-martin Mon, 08/20/2007 - 06:30
  • Bronze, 100 points or more
You can customize certain elements, such as the corporate logo, of the AnyConnect client graphical user interface that the remote user sees upon logging in. You customize the AnyConnect Client user interface by replacing files that affect the interface with your own, custom files. For example, with a Windows installation, you can change the company logo from the default Cisco logo by replacing the file company_logo.bmp with your own file.
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect20/administrative/guide/admin8.html
050878james Mon, 08/20/2007 - 08:37
Hello !!
Thank You for reply !!
This link helps a lot, very usefull. So this problem is fixed now.
One another thing when we are talking about this is: I am having a problems with JAVA for example you know when we add the RDP link under customization so the users can open RDP via java without to need to connect with Anyconnect client, so when the users click on the terminal server RDP link we created, java window opens but it is small and not possible to resize at all, even if I specify the 1024x760 reolution in the link as Cisco described, any suggestions ?? what the problem could be ?
Thank You again
Best regards
