VoIP home solutions
Aug 11th, 2007
Hello, I'm new about voice.Here is my requirement:
1.I have meshed site to site VPN among 3 locations, can I use Cisco ATA/Linksys PAP2 adapter to connect anolog phone and call the other two remote sites? These 3 sites can be assigned dial number like 10,20,30
2. if this not possible, can I use ATA186/linksys PAP2 as a "hot line" which is peer to peer without any numbers to dial?
3. if these VoIP adapter can not do so, what's your suggestion ? Thanks in advanced
Paolo Bevilacqua Sat, 08/11/2007 - 15:10
  • Hall of Fame,
    Founding Member
What you want to do is called direct IP call (no SIP proxy). I've looked at the linksys ATA manual and doesn't appear that is supported.
So you can either use a small IP like linksys also does, or use phones that support direc IP call. For example, the snom brand does.
