My ASA is not installing dynamic routes into its routing table.
Aug 11th, 2007
Our border router is sending a default route only but our ASA is not learning the route. We have run debugs and we have verified that it is being seen by the ASA but the route is not being installed in the routing table. Any ideas?
JORGE RODRIGUEZ Sun, 08/12/2007 - 09:47
  • Green, 3000 points or more
John, it is hard to tell without seeing the configs between asa and border router.., please post configs for forum to see and help.
johnsos Sun, 08/12/2007 - 19:45
Ooops here is my config hope it is enough. It also show the debug for both the border router and the ASA.
Border Router RIP Config
router rip
version 2
redistribute bgp 65002 metric 1 route-map DEFAULT_ONLY
passive-interface ATM1/0.1
passive-interface ATM1/0.2
passive-interface GigabitEthernet2/0
network 192.168.200.0
route-map DEFAULT_ONLY permit 10
match ip address 10
access-list 10 permit 0.0.0.0
debug on border router
Aug 12 22:27:59.731 cdt: RIP-DB: redist 0.0.0.0/0(metric 0) to RIP
Aug 12 22:27:59.731 cdt: RIP-DB: adding 0.0.0.0/0 (metric 1) via 204.147.83.189
on GigabitEthernet2/0 to RIP database
Aug 12 22:28:10.615 cdt: RIP: sending v2 update to 224.0.0.9 via FastEthernet0/0
(192.168.200.49)
Aug 12 22:28:10.615 cdt: RIP: Update contains 1 routes
Aug 12 22:28:10.615 cdt: RIP: Update queued
Aug 12 22:28:10.615 cdt: RIP: Update sent via FastEthernet0/0
ASA config
router rip
passive-interface dmz1
passive-interface inside
passive-interface intersite
version 2
no auto-summary
debug on ASA:
RIP: received v2 update from park-scrn-rtr-i on outside
0.0.0.00.0.0.0 via 0.0.0.0 in 1 hops
route outside 0.0.0.0 0.0.0.0 park-scrn-rtr-i 99
route intersite 0.0.0.0 0.0.0.0 172.31.254.242 100
access-list outside_access_in extended permit udp any eq rip interface outside eq rip
access-list outside_access_in extended permit udp any eq rip host ASA-1-Outside-Int eq rip
srue Sun, 08/12/2007 - 20:01
  • Blue, 1500 points or more
you already have two default routes on your asa device, both with administrative distances lower than RIP.
Can you explain what you're trying to accomplish?
johnsos Sun, 08/12/2007 - 20:06
Notice the metric though. As soon as the dynamic rip route shows up with a metric of 1 it should in theory take over or trump these routes. It work that why with the PIX anyway. So I'm making some assumptions.
srue Sun, 08/12/2007 - 20:08
a metric is different than administrative distance. The assigned RIP metric doesn't matter be/c the the other default routes with lower AD's are matched first in the selection process to see which routes go into the routing table.
johnsos Sun, 08/12/2007 - 20:31
Ok it must of worked a bit different than how we had it in the pix. Or I probably looked at it incorrectly I will have to look at the config for the pix again.
What I did was moved both static defaults to what the ASA calls METRIC in ASDM under configuration,device setup, static routes to 122 and 121 and then I started learning the route from RIP. Verified this by going to Monitoring, Routing, Routes here it does show both AD/Metric which makes sense to me. The ASDM gui was makeing me question METRIC. They should probably change this in the GUI. Workin now. Thanks for your help.
