RME ???/
Aug 12th, 2007
I have install RME 3.5. when i check administration --availabilty i can not found 1800 , 2800 and 5800 series router. for this i can get full availabialty information of these router. so i ned latest IDU of RME ???.
Joe Clarke Sun, 08/12/2007 - 10:12
You did not give the specific sysObjectIDs for these devices, but you will need at least RME 3.5 IDU 10.0 to support the 2800 and 1800 series routers. The AS5800 and 5850 are supported in RME 3.5 without any IDU.
However, availability works with any SNMP-capable device (even non-Cisco devices). The caveat is that you cannot have more than 1000 devices polled by availability. This assumes you have a multi-processor server with a lot of RAM.
