running with busy flag set !!!!!!!!!!!
Aug 12th, 2007
I am facing in campus Maanger 3.5
after install CM when i open topology service then error in come your ANI serving is not connect and CM restart.
when i go process management i found this message in ANI server :"running with busy flag set"
but in discover metrics i found discovery device via the seed device.
so how i overcome this .
Biplob
Joe Clarke Sun, 08/12/2007 - 09:45
Running with busy flag set is the correct state for ANIServer. However, Campus Manager 3.5 does not exist. Exactly what version of Campus Manager are you using? what version of the Java Plug-in do you have installed on your client?
