bgp peer groups
Aug 12th, 2007
hi, i have a little confusion regarding peer groups so plz help me out. Suppose i have a router RA running bgp and it has 5 ebgp neighbours that are all grouped in a peer group, now i want to run the next-hop-self command on only one neighbour but when i do it like this
neighbour (neighbour ip ) next-hop-self
% Invalid command for a peer-group member
so what can i do to solve this problem, remember i want this neighbour to be the part of peer group but i also want to run some independent commands on it so is there any way to do it ?
thanks
mohammedmahmoud Sun, 08/12/2007 - 03:41
  • Green, 3000 points or more
You can't define a specific outbound routing policy to a single peer-group member, outbound routing policies can only be applied to the whole peer-group, and thus you'll have to decide either to remove the peer from the group or do the command to the whole group.
One comment here, you don't need the next-hop-self for your ebgp neighbors it is done by default.
HTH,
Mohammed Mahmoud.
illusion_rox Sun, 08/12/2007 - 09:15
oh yes Mahmoud bhai my mistake, actually in my scenario i had ebgp peering with 3 routers and 1 confederation ebgp with another router RB, so for RB the next-hop-self command wasnt there by default.
Second i read in jeff doyle routing tcp/ip volume 2 that even after we define peer groups we can still assign indiviual policies to its member so u think that comment is mistaken or did i misunderstood it ??
waiting for reply
thanks
mohammedmahmoud Sun, 08/12/2007 - 09:29
Hi Ovais,
You can change the incoming policies as you like but not the outgoing policies.
HTH,
Mohammed Mahmoud.
