reboat on rommon mod
Aug 12th, 2007
hi Experts,
each time i restart my 2811 router it's drive me to the rommon mod and i have to select boot from flash i intered boot system command and it's shown as followed
boot system flash:c2800nm-ipbase-mz.124-11.T.bin
Overall Rating: 5 (1 ratings)
mohammedmahmoud Sun, 08/12/2007 - 04:51
Hi Mohamed,
can you please paste the show version and dir flash:
Mohammed Mahmoud.
mohamedaman Sun, 08/12/2007 - 05:04
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(11)T, RELEASE
Technical Support:
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 18-Nov-06 17:16 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Wasla uptime is 1 hour, 23 minutes
System returned to ROM by reload at 10:24:21 UTC Sun Aug 12 2007
System image file is "flash:c2800nm-ipbase-mz.124-11.T.bin"
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FCZ111570E5
2 FastEthernet interfaces
4 Serial(sync/async) interfaces
2 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x3920
mohamedaman Sun, 08/12/2007 - 05:06
ompactFlash directory:
File Length Name/status
1 19656184 c2800nm-ipbase-mz.124-11.T.bin
[19656248 bytes used, 44569028 available, 64225276 total]
mohammedmahmoud Sun, 08/12/2007 - 05:17
hi Mohamed,
Please change the Configuration register to 0x2102 via the config-register command and reload the router .
Mohammed Mahmoud.
mohamedaman Sun, 08/12/2007 - 05:38
great it's work....
how can i get back the SDM as it's erased from the flash:
(i don't have cco password to download it)
