Cannot telnet to Cisco 7206 NPE-G2
mrcomm2000
Dear All,
We have an MPLS/VPN Network, all our PEs are cisco 7206 NPE-G2 Routers , all the PEs are making OSPF , MPLS with the P-Router and MP-BGP with a Router Reflector Router
After a while we found a problem in the Router that we couldn't telnet to the router through the Loopback0 Interface
We only successfully telnet to the PEs through the IP on any VRF configured on the PEs
After we telnet to the IPs through the IP inside the VRF , we successeded in telneting to the Loopback 0 interfac in the global routing interface
After a while the problem repates again , and each time solved by the telnetting to any IP inside the VRF
We are using the following Image :c7200p-advipservicesk9-mz.124-11.T1.bin
Any advice
Thanks in Advance
deveshkumar
there is missing routes for loopback ips,
u need to put those routes in the same domain , where ur source for telnet resides.
Dears,
I could ping the Router with its loopback IP address while i can't telnet to it
There is no problem in the routing or the source interface for the telnet session
