GLBP with pix
Aug 12th, 2007
sw---pix---Sw------R1--------ISP1
---pix--sw-------R2--------ISP2
i want to make load sharing between the two routers .
is GLBP is a suitable solution with pix and if it can how can i configure it (which virtual ip gateway that will be assigned by pix)
my network topology attached with my conversation
thx.
intelide3 Sun, 08/12/2007 - 06:48
hi,
are those L3 switches? can you just configure GLBP from there?
HTH.
sameh_hassan Sun, 08/12/2007 - 12:22
ok i know ,but my problem how can i configure GLBP in case of the presence of pix ?
is the virtual ip address (virtual gateway) assigned to pix or lan users ???
