dot1q ----- SW 2950
Aug 12th, 2007
Does Sw 2950 support command:
switchport trunk encapsulation dot1q.
i did not find this command.
any help
ankbhasi Sun, 08/12/2007 - 07:30
Hi Friend,
2950 only supports dot1q which is a default encapsulation and that is the reason command to configure dot1q is not available.
Just issue this command
"swutchport mode trunk" and you are good to go.
*Pls rate all helpfull post
cindylee27 Sun, 08/12/2007 - 18:38
Does it means that if there is other switches brand that only support EITF, 2950 wont be able to work with them?
Thanks in advanced.
sundar.palaniappan Sun, 08/12/2007 - 19:20
That's correct.
If there is another switch out there that's configured to do ISL encapsulation then 2950 wouldn't be able to form a trunk with it. 802.1q is industry standard protocol whereas ISL is Cisco Proprietary and therefore you probably mightn't run into a scenario where ISL is supported but not 802.1q.
