Getting scripts
Aug 12th, 2007
hi all,
i have several vlans which have to access my domain controller and active directory to get authentication and scripts, there is a problem with getting the scripts. how can i define an ACL which would allow them to only get the scripts.
Jagdeep Gambhir Mon, 08/13/2007 - 05:29
For this you need to set up machine authentication on the network (Radius).
Q. What is machine authentication and how does Cisco Secure ACS support it today?
A. Machine authentication is used at boot time to authenticate and communicate with Windows domain controllers to pull down machine group policies independently of an interactive user authentication session. Cisco Secure ACS provides a mechanism to allow machine authentication on an 802.1X port before a user session is initiated. This is done by communicating the machine name with or without a valid certificate (depending on the EAP method used) to the Cisco Secure ACS server for machine identity verification. Cisco Secure ACS version 3.2 supports machine authentication using either EAP-TLS or
PEAP-EAP-MSCHAPv2 against Windows Active Directory.
Hope that helps
~JG
Please rate helpful posts
