USB to Serial adapter connection
Answered Question
Aug 12th, 2007
I have a iBook G4. Console cable, and USB to Serial adapter cable. I would like to be able to console into a Cisco router, I am using Zterm as was recommanded early for Hyperterminal. it seems that the connection is there. when I click on the Zterm app I get a blank white screen with
ATE1 V1
OK
any one have any idea how to use this terminal or help get connected
I know that I can use Terminal to telnet into the router, but I need to console in first to set up the basic configuration.
Correct Answer by mohammedmahmoud about 9 years 6 months ago
Hi Karim,
I am very glade that you did it :) please do enjoy your lab, i'll always be here if you have further problems, and thanks for the nice rating.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (5 ratings)
guruprasadr Sun, 08/12/2007 - 20:57
HI,
You can use "Hyperterminal" for this kind of Setup.
Setup as below:
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
PLS RATE if HELPS
Best Regards,
Guru Prasad R
mohammedmahmoud Sun, 08/12/2007 - 22:25
Hi Karim,
For Zterm, generally configure 9600 baud, 8 bits, no parity, 1 stop bit and you must select usbserial if you're using a usb-to-serial converter.
HTH,
Mohammed Mahmoud.
cisco steps Mon, 08/13/2007 - 07:03
thanks for the reply all of you, the issue that I have is where I can configure all this >>>>
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
the Screen is blank so how I will configure it ..I do not see any options where I do that ..
mohammedmahmoud Mon, 08/13/2007 - 12:05
Hi Karim,
As illustrated in the link you've found, first you need to go to settings -> Modem Preferences -> select usbserial0 as the default modem and then edit your connection parameters as said in earlier posts, and it should be that simple.
HTH,
Mohammed Mahmoud.
mohammedmahmoud Tue, 08/14/2007 - 12:59
Hey Karim,
How do you do :), you'll need to make sure that you've installed the driver for the usb-to-serial converter.
HTH,
Mohammed Mahmoud.
cisco steps Tue, 08/14/2007 - 13:50
Mo .. I did buy a generic usb/serial and it did not come w/ the driver... do I have to buy an other one// Thanks
cisco steps Sun, 08/19/2007 - 09:57
Hi Mo
I did try to download the driver but I get a Chinese characters. I will try it again today... Tanks
cisco steps Mon, 08/20/2007 - 05:16
That did it Mo .. thanks for taking your time to help me with the issue. it works better then windows hypererminal.. :-)
Correct Answer
mohammedmahmoud Mon, 08/20/2007 - 05:49
Hi Karim,
HTH,
Mohammed Mahmoud.
usasigcis Tue, 07/23/2013 - 20:53
in mac open "terminal " under utilities and type "screen /dev/tty.Keyserial"
