Show conn file (ASA)
Aug 12th, 2007
Hello, i wanna ask if i could get the 'show conn' data in ASA or not. I want to analyze the connections and limit traffics other than connection in particular time.
I can't use "term len 0" as in router and switch and just capture the show command.
srue Sun, 08/12/2007 - 20:45
  • Blue, 1500 points or more
'pager 0' is the equivalent pix command for term len 0.
rajbhatt Thu, 08/16/2007 - 02:47
Hi ,
Try
config#no pager
That would do the trick
Raj
