How to delete a folder in Flash card.
Aug 12th, 2007
I have a 1841 router with me, would like to ask one newbie Question, what is the proper way to delete a specific folder in the Flash card.
guruprasadr Sun, 08/12/2007 - 23:58
  • Gold, 750 points or more
HI, [Pls Rate if HELPS]
Execute the below steps:
Router#show flash:
Router#delete flash:
Router will ask you for a Confirmation before Delete.
INFO: Use the Delete command to remove the current IOS software image stored in Flash memory:
Router#delete
PLS RATE if HELPS
Best Regards,
Guru Prasad R
mohammedmahmoud Mon, 08/13/2007 - 00:18
  • Green, 3000 points or more
You can use the delete command to remove a file, but to remove a folder you must use rmdir command.
HTH,
Mohammed Mahmoud.
guruprasadr Mon, 08/13/2007 - 00:57
HI,
Thanks Mohammed Mahmoud & Narayan.
Best Regards,
Guru Prasad R
