1841 Alignment Error
Aug 13th, 2007
I have Cisco 1841 router and see alignment error. The old IOS was c1841-advsecurityk9-mz.124-11.T2.bin and as per cisco suggestion upgraded to c1841-advsecurityk9-mz.124-15.T1.bin
Still i see alignment error. As Cisco suggestion the alignment errors are due to misaligned reads and writes caused by a software failure and suggests to upgrade to latest IOS.
I have configured IPSec tunnels and not used AIM VPN module.
Router#sh alignment
Alignment data for:
1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(15)T1, RELEASE SOFTWARE (fc2)
Compiled Wed 18-Jul-07 04:47 by prod_rel_team
Total Corrections 3, Recorded 2, Reads 3, Writes 0
Initial Initial
Address Count Access Type Traceback
EE95B1CE 1 32bit read 0x6029AAF4 0x6029DC60 0x600297AC 0x621D37B8
0x621DAE7C 0x621D728C 0x621D7558 0x6004A188
EE8F99CE 2 32bit read 0x6029AAF4 0x6029D650 0x600297AC 0x621D37B8
No spurious memory references have been recorded.
Any one has suggestion to this problem?
guruprasadr Mon, 08/13/2007 - 01:42
HI,[ PLS RATE IF HELPS ]
The failure was caused by a software defect.
Refer Cisco Bug Reports for FIX: The IOS "C1841-ADVSECURITYK9-M" has Several Bugs and listed below the BUG ID's for the same. Use the correct IOS in which the BUG has been FIXED in. Pls see below for Details:
BUGID:CSCsd69052
Fixed in:12.4(9.15) 12.2(18)SXF6 12.2(18.5.11)SXF 12.2(32.8.11)SX2 12.4(9.15)T
Title:Netbios/NAT optimization
BUGID:CSCse70141
Fixed in:12.4(12.4) 12.4(12.1)T 12.4(12.2)PI6
Title:Tracebacks @ ipnat_nbss_is_special_packet
BUGID:CSCsh02342
Fixed in:12.4(16.6) 12.4(13.9)PI6a 12.4(16.6)T
Title:NAT cannot create new inside entry
BUGID:CSCsi93916
Title:Alignment Error/ Traceback @ ipnat_nbss_is_special_packet/ latest SPUD
PLS RATE IF HELPS
Best Regards,
Guru Prasad R
ckuriyar74 Mon, 08/13/2007 - 03:29
GuruPrasad,
I tried to serach the right IOS in which the alignment error is fixed. When i see the bug toolkit Cisco says Right now there is no workaround.
Can you suggest me the right IOS.
guruprasadr Mon, 08/13/2007 - 04:54
HI,
You don't have to Search for an IOS specifically which has alignment error is fixed.
See my Previous Post in the "Fixed in" line where i have listed the IOS Version in which the BUG has been fixed.
DO RATE ALL HELPFUL Posts
Best Regards,
Guru Prasad R
Andyfweih Mon, 08/13/2007 - 02:38
Dear business partners & valued customers :
I am pleased to enclose it for your reference.
We can give you better price depending on the items and Qty.
Large quantity new & used Cisco and networking products that aren't
included in this catalogue. Feel free to contact us with your
requirements.
50% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-24TS-S
WS-C3560-48TS-S
WS-C3560G-24TS-S
WS-C3560G-48TS-S
WS-C3750-24TS-S
WS-C3750-48TS-S
WS-C3750G-12S-S
WS-C3750G-24TS-S
WS-C3750G-24PS-S
60% discount of GPL!! (Original new, 1 year warranty)
WS-C3560-48TS-E
WS-C3560-24TS-E
WS-C3750G-24T-E
WS-C3750G-24TS-E
WS-C3750G-24PS-E
WS-C3750G-48TS-E
WS-C3750G-48PS-E
Looking forward to receiving your enquiries soon.
Best Regards
Andy Feng
FEDON(INT'L)DEVELOPMENT LTD
MSN:[email protected]
Email:[email protected]
Http://fweih.diytrade.com
ckuriyar74 Thu, 08/16/2007 - 04:10
Guruprasad,
Below is the Cisco Bugtoolkit output.
Symptom:
A Cisco router can experience Alignment Errors related to NAT. This Alignment Errors are related to NBSS.
Workaround
As cisco says the status is still open.
