enable logging for permitted traffic on FWSM v3.1
Aug 13th, 2007
Hi all,
I'm trying to enable logging for permitted traffic on FWSM running version 3.1 but with no success, I know it seems easy to do it but believe me I got frustrated trying.
Note:
I tried the same for the denied traffic and magically worked fine.
Could you pls shed a light on this !!
Belal
lowen Tue, 08/14/2007 - 11:23
Your problem probably has to do with the level of the messages. You have to ensure that the messages you want to log match the level you're logging at. If you're logging at the "errors" level (logging trap errors), add "log errors" to the end of all your permit ACEs, and do the following:
logging message 302015 level errors
logging message 302014 level errors
logging message 302013 level errors
logging message 302016 level errors
This will log the start and end of all tcp and udp connections. You may need to "promote" other messages for other types of traffic.
balsheikh Tue, 08/14/2007 - 23:25
Hi Lowen,
in this case I have to go through the message IDs and find out the required IDs to be enabled.
good to hear that from u, I'll give it a try and get back to you.
Appreciated..
