problem with as/400 and ipsec tunnel
Aug 13th, 2007
Hi all,
i've a problem with some application on as400 running in an ipsec tunnel between 2 IOS router.
99% of application work correctly, but when the command "dspmsg" is invoked the application stop to work. All other application in tunnel works fine and the tunnel stay up.
Has anyone had the same problem?
Could this behaviour due to the overhead generated by ipsec?
Thanks in advance for any suggestion
