Multicast on FWSM
HI,
I am testing my FWSM for Multicast support.
i have made a test set-up..
The Multicast sendor is in "inside"(VLAN 10) & reciever is in "outside"(VLAN 203).
Both the interfaces are not created on MSFC. its only L2 Vlan on 6509E switch.
I tried all my normal application works but multicast is not working though i have configured following on FWSM:
multicast-routing
interface Vlan10
nameif inside
security-level 100
ip address 5.5.5.3 255.255.255.0
igmp join-group 239.255.1.1
pim
interface Vlan203
nameif outside
security-level 0
ip address 6.6.6.1 255.255.255.0
pim
access-list ins_out extended permit ip 5.5.5.0 255.255.255.0 6.6.6.0 255.255.255.0 log debugging
access-list ins_out extended permit ip 5.5.5.0 255.255.255.0 224.0.0.0 240.0.0.0 log debugging
access-list outside_access_in extended permit ip 6.6.6.0 255.255.255.0 5.5.5.0 255.255.255.0 log debugging
access-list outside_access_in extended permit ip 6.6.6.0 255.255.255.0 224.0.0.0 240.0.0.0 log debugging
static (inside,outside) 5.5.5.0 5.5.5.0 netmask 255.255.255.0
access-group ins_out in interface inside
access-group outside_access_in in interface outside
end
Please suggest the problem & workaround.
Thanks in advance!
regards
zubairjalal Mon, 08/13/2007 - 22:52
Hi.
I think the problem lies in the ACL. Please change the ACL so that it points to specific multicast address..
access-list ins_out extended permit ip 5.5.5.0 255.255.255.0 host 239.255.1.1 log debugging
rigoberto.cintr... Tue, 08/14/2007 - 05:06
I don't think the acl is the problem, 224.0.0.0/4 cover the 239.255.1.1.
What I'll try is just make sure that igmp is enable in the necessary interfaces but don't use the join option.
