acs upgrade problems
Aug 13th, 2007
after upgrade of acs 4.1 the tacacs+ administration( on reports section) database does not populate with commands that administrators enter on cisco routers.
any ide ?
thanks.
Overall Rating: 5 (1 ratings)
adriatikb Mon, 08/13/2007 - 07:14
thank you prem , latest patch for 4.1(1) Build 23 which is Patch Acs-4.1.1.23.5-SW is the solution.
