Antenna cables
Aug 13th, 2007
I generally deploy the 1231G cisco ap's along with two 5dbi cisco antennas [air-ant2506]. My predecessor used to purchase 6' antenna cables to go along with them.
I found this odd because the cabling tech would only mount the antennas about a foot and a half away from the AP and then COIL up the slack [isn't that defeating the purpose].
My thought is that you generally don't need to buy antenna cables unless you're having to mount the antennas a good distance away from the AP. But if the antennas are nearby, don't waste the money.
Am I right?
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 08/13/2007 - 07:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ronald,
You are most correct here :) It sure sounds like the three foot cable that ships with a 2506 would be plenty. Additional length only adds loss and unsightly coils of cable. Maybe there was some question of how/where to mount the antennas that came into play here? You just never know.
Hope this helps!
Rob
scottmac Mon, 08/13/2007 - 13:20
  • Green, 3000 points or more
In the situation you describe, I can only think it might have baan added as a "Service Loop" so the AP could be taken down (leaving the antennas in-place).
If the cabling is redundant, get rid of it, it'll cut down on the signal (strength) input to the antenna.
The extra connections are just additional points of failure and / or corrosion.
Good Luck
Scott
