Cisco VPN
Aug 13th, 2007
I am using the Cisco VPN Client. I can connect to the cisco device, username and password are correct. Everything works fine as far as connecting. The problem is when the VPN client is connected the pc can not access the Internet. If you disconnect the client everything works fine. When I run ipconfig there is a gateway for all connections except the vpn connection. Is there a setting I am missing in the router?
farkascsgy Mon, 08/13/2007 - 07:48
Did you configured split-tunneling, with this feature you can limit which domains is behind the VPN tunnel.
Please rate me if I helped.
kbrown001 Mon, 08/13/2007 - 07:54
Other users on the same domain can connect with no problem.
