6509 Feature Set?
Answered Question
Aug 13th, 2007
How do I know what software is currently enabled on a 6509? I am trying to select an IOS to download to add a WS-X6408A-GBIC blade. We currently have:
sh version
WS-C6509 Software, Version NmpSW: 7.6(1)
Copyright (c) 1995-2003 by Cisco Systems
NMP S/W compiled on Apr 16 2003, 17:59:12
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:RTSYNC_cat6000-sup2k8.7-6-1.bin'
System Configuration register is 0x2
Hardware Version: 3.0 Model: WS-C6509 Serial #: TSC07100014
PS1 Module: WS-CAC-2500W Serial #: ART06500069
PS2 Module: WS-CAC-2500W Serial #: ART0708016L
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL0706CMUB Hw : 4.1
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.6(1)
Sw1: 7.6(1)
Sw :
2 2 WS-X6K-SUP2-2GE SAL0706CM31 Hw : 4.1
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.6(1)
Sw1: 7.6(1)
Sw :
3 48 WS-X6148-GE-TX SAD072002XD Hw : 1.0
Fw : 7.2(1)
Sw : 7.6(1)
15 1 WS-F6K-MSFC2 SAL0708DBNV Hw : 2.5
Fw : 12.1(13)E4
Sw : 12.1(13)E4
16 1 WS-F6K-MSFC2 SAL0708DBNN Hw : 2.5
Fw : 12.1(13)E4
Sw : 12.1(13)E4
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
2 131072K 65434K 65638K 32768K 15039K 17729K 512K 284K 228K
Correct Answer by Jon Marshall about 9 years 5 months ago
Jim
You don't need to upgrade as you are already running a higher version of CatOS than 7.2 ie. you are running 7.6(1).
No harm in plugging in. If the module is not supported by the software then it is just disabled. The 6500 modules are hot swappable.
Upgrading from hybrid ie. CatOS on the switch/IOS on the MSFC to native ie. one image of IOS involves rewriting a lot of the config from CatOS to IOS. Cisco have a tool to help but it is not perfect. IOS (native) is the way Cisco seem to be going in the long run but to be honest unless you have a pressing need for a feature in the native code set that isn't in CatOS i would stick where you are.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 08/13/2007 - 11:33
you are running Catos 7.6(1) ie.
And your IOS on the MSFC is
12.1(13)E4
Jon
Edit - i believe the minimum CatOS needed is 7.2 so you should be okay. Have you tried inserting the module to see if it is recognised ?
jim.billings Mon, 08/13/2007 - 12:06
No I have not. Is there any harm in plugging it in before we go to the trouble of upgrading the system software? What would the process be to upgrade to CatOS 7.2? With the switch covered by Smartnet could we upgrade to IOS? If so would you recommend it?
We are using it for basic networking with departmental VLAN's.
Jim
Correct Answer
Jon Marshall Mon, 08/13/2007 - 14:45
Jim
Jon
jim.billings Mon, 08/13/2007 - 18:59
That is actually the best news I have had regarding this project.
Jim
