TFTP boot directory on Ciscoworks LMS 2.6
Answered Question
Aug 13th, 2007
For Ciscoworks LMS 2.6 (Windows), should the TFTP boot directory be empty?
C:\Program Files\CSCOpx\tftpboot
Looking through the directory, I noted alot of old configuration files in there.
Correct Answer by Joe Clarke about 9 years 9 months ago
Typically, the directory should be empty unless software or config jobs are running, or someone is using the directory for other purposes. Occasionally, crashed jobs can leave leftover files in tftpboot. Some of these may even be non-zero length. If you know there are no active jobs running, files named DATE-DEVICE.cfg (e.g. 20060205142402101-14.32.12.25.cfg) can be safely deleted.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 08/13/2007 - 15:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
david.fernandes... Mon, 08/13/2007 - 17:04
Thanks! I think all the files have that notation so I'll be removing alot of cruft.
