2600 to LAN connection problems to other VLANs
I have a cisco 1800 at a new location connecting a cisco 2600 in my office over T1. these 2 connect (cdp, ping, trace, telnet)
the 2600 connect my LAN via cisco 3650
the 2600 int configs:
Ethernet0/0 is up, line protocol is up
Hardware is AmdP2, address is 0001.429f.6f20 (bia 0001.429f.6f20)
Description: uplink core3550
Internet address is 192.168.42.6/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
3463 packets input, 390580 bytes, 0 no buffer
Received 2459 broadcasts, 0 runts, 0 giants, 0 throttles
18 input errors, 18 CRC, 15 frame, 0 overrun, 0 ignored
3398 packets output, 235675 bytes, 0 underruns
2236 output errors, 0 collisions, 2 interface resets
2236 lost carrier, 0 no carrier
interface Ethernet0/0
description uplink core3550
ip address 192.168.42.6 255.255.255.0
full-duplex
end
the 3650 int configs:
GigabitEthernet0/29 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0017.e040.419d (bia 0017.e040.419d)
Description: line to 292 madison Verizon 9062
Half-duplex, 10Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:31, output 00:00:00, output hang never
Output queue: 0/40 (size/max)
5 minute output rate 2000 bits/sec, 2 packets/sec
1204 packets input, 111006 bytes, 0 no buffer
Received 78 broadcasts (0 multicast)
0 watchdog, 47 multicast, 0 pause input
13966 packets output, 2014761 bytes, 0 underruns
0 output errors, 4 collisions, 1 interface resets
interface GigabitEthernet0/29
description line to Verizon
switchport access vlan 42
switchport mode access
end
anything within VLAN42 work fine:
I can access 192.168.42.6 from cisco3650
I can access any 192.168.42.x from the 2600 to LAN
any other VLAN doesn't work:
I can't access 192.168.42.6 from any other VLAN on teh network
I can't access any other VLAN from 192.168.42.6 to LAN
glen.grant Mon, 08/13/2007 - 14:19
  • Purple, 4500 points or more
You might want to post the whole router config and then repost your question . Its not clear where the other vlans are located , is the 3560 doing routing etc .....Are you using a routing protocol or static routes all over the place ?
Edison Ortiz Mon, 08/13/2007 - 14:25
  • Hall of Fame,
    Founding Member
In addition to posting the router config, you may want to post the 3560 Switch config.
Do you have an 'interface vlan 42' with an IP address associated to that Vlan on this switch ?
You also need to address the duplex mismatch you have going there. The switchport is set to auto/auto while the router is set to full-duplex. I recommend manually setting the duplex and speed on the switchport.
changed the duplex, here is the updated int on 3650:
Full-duplex, 10Mb/s, media type is 10/100/1000BaseTX
Last input 00:00:14, output 00:00:00, output hang never
5 minute output rate 1000 bits/sec, 2 packets/sec
2569 packets input, 251679 bytes, 0 no buffer
Received 277 broadcasts (0 multicast)
0 watchdog, 244 multicast, 0 pause input
34939 packets output, 5180726 bytes, 0 underruns
0 output errors, 4 collisions, 3 interface resets
0 babbles, 2 late collision, 0 deferred
VLANs on 3650:
VLAN Name Status Ports
1 default active Gi0/3, Gi0/4, Gi0/5, Gi0/6
Gi0/8, Gi0/27, Gi0/49, Gi0/51
Gi0/52
42 VLAN0042 active Gi0/1, Gi0/9, Gi0/22, Gi0/29
Gi0/30, Gi0/31
43 vlan43 active Gi0/10, Gi0/11, Gi0/12, Gi0/13
Gi0/14, Gi0/15, Gi0/16, Gi0/17
Gi0/18, Gi0/19, Gi0/20, Gi0/21
44 VLAN0044 act/lshut
128 VLAN0128 active Gi0/25, Gi0/26, Gi0/28, Gi0/32
Gi0/33, Gi0/34, Gi0/35, Gi0/36
Gi0/37, Gi0/38, Gi0/40, Gi0/41
Gi0/42, Gi0/44, Gi0/48
200 VLAN0200 active Gi0/2, Gi0/7, Gi0/24, Gi0/39
Gi0/43, Gi0/47, Gi0/50
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
everything on my network go via this switch
I would expect any other VLAN to be able to access 192.168.42.6 since they go to the same switch (192.168.200.254 is VLAN200 gateway) but it's not...
what other configs do you want to see here?
Edison Ortiz Mon, 08/13/2007 - 17:10
  • Hall of Fame,
    Founding Member
The full running config from both the router and switch will be helpful.
in addition,
connection to 192.168.42.6 fail when I use VLAN1 connecting from a directly connected switch via trunk (to 2650)
I have no problems accessing other 192.168.42.x routers the same way
when you set the ip route it refers to the next hop which in my case still doesn't exist (no network on the remote location until I can figure out my end)
