Non existent devices in LMS2.6
Aug 13th, 2007
  • Bronze, 100 points or more
Can anyone tell me what LMS does with devices that no longer exist in the network?
Does it purge it at some point or do I have to delete it manually? Thanks
Joe Clarke Mon, 08/13/2007 - 15:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You have to delete them manually from the Device Credential Repository. This will remove them from all LMS applications.
kwillacey Tue, 08/14/2007 - 06:04
Thanks but how come there is no mechanism to automatically delete devices no longer present? Are there future plans for this?
Joe Clarke Tue, 08/14/2007 - 08:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The problem with doing this automatically is that there is no good place to put it. The logical place to put such a feature is in DCR. However, DCR doesn't actually communicate with the device (not yet anyway), so it wouldn't know if the device is unreachable or not. If you put the feature in RME, then what if RME isn't available?
That said, there are some features to aid with trimming devices. Campus Manager has a script called DeleteDevices (under NMSROOT/campus/bin) which allows you to delete unreachable devices from Campus Manager only. In Common Services 3.1 (part of LMS 3.0) when you choose to delete devices, you get a pop-up asking if you want to delete all the devices, or just those that are not managed by any application. While this still wouldn't give you what you want, it may help prune other unwanted devices.
