RIPV2 & ACL
Answered Question
Aug 13th, 2007
I am seeing my default route also being distributed even when I have a ACL specifying only one of my static routes? Why is the default route being distributed? Thanks
Here is main part of the config on router 2:
interface Loopback0
ip address 192.168.40.1 255.255.255.0
interface Serial1/1
no ip address
encapsulation frame-relay
serial restart-delay 0
frame-relay lmi-type ansi
interface Serial1/1.101 point-to-point
ip address 192.168.11.2 255.255.255.0
frame-relay interface-dlci 101
router rip
version 2
redistribute static
passive-interface Loopback0
network 192.168.11.0
network 192.168.40.0
distribute-list 14 out static
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.40.2
ip route 10.1.3.0 255.255.255.0 Loopback0
access-list 14 permit 10.1.3.0 0.0.0.255
the routes on Router 1:
Gateway of last resort is 192.168.11.2 to network 0.0.0.0
C 192.168.10.0/24 is directly connected, Loopback0
R 192.168.40.0/24 [120/1] via 192.168.11.2, 00:00:11, Serial1
C 192.168.11.0/24 is directly connected, Serial1/1.101
10.0.0.0/24 is subnetted, 1 subnets
R 10.1.3.0 [120/1] via 192.168.11.2, 00:00:11, Serial1/1.1
C 192.168.1.0/24 is directly connected, FastEthernet0/0
R* 0.0.0.0/0 [120/1] via 192.168.11.2, 00:00:11, Serial1/1.101
R1#sh ip rip da
0.0.0.0/0 auto-summary
0.0.0.0/0
[1] via 192.168.11.2, 00:00:13, Serial1/1.101
10.0.0.0/8 auto-summary
10.1.3.0/24
192.168.1.0/24 auto-summary
192.168.1.0/24 directly connected, FastEthernet0/0
192.168.11.0/24 auto-summary
192.168.11.0/24 directly connected, Serial1/1.101
192.168.40.0/24 auto-summary
192.168.40.0/24
Correct Answer by Edison Ortiz about 9 years 11 months ago
Change
to
distribute-list 14 out Serial1/1.101
Then, clear ip route on R1 and you should have the correct results.
Correct Answer by mohammedmahmoud about 9 years 11 months ago
hi,
Remove the static keyword in the "distribute-list 14 out static" command.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (2 ratings)
Correct Answer
mohammedmahmoud Mon, 08/13/2007 - 14:35
  • Green, 3000 points or more
hi,
HTH,
Mohammed Mahmoud.
fgarakani Mon, 08/13/2007 - 15:03
Can you tell me what "static" means/does at the end of "distribute-list 14 out static"? I am really puzzled?
Thanks for your help,
Edison Ortiz Mon, 08/13/2007 - 15:36
  • Hall of Fame,
    Founding Member
Don't be too puzzled, it doesn't work as advertised. It's a bug (CSCds89505). It does not only affects static but other routing protocols such as OSPF, EIGRP and BGP.
mohammedmahmoud Mon, 08/13/2007 - 15:53
Agree with Edison, practically speaking it never works this way.
HTH,
Mohammed Mahmoud.
Correct Answer
Edison Ortiz Mon, 08/13/2007 - 14:42
  • Hall of Fame,
    Founding Member
Change
to
