SSH at PRP ethernet ports.
Aug 13th, 2007
Anybody knows if it is possible to configure ssh (client and server) at the PRP2 Ethernet ports using private IPs for a GSR router?.
do this ports share the routing table of the rest of the GSR?
Any security recommendation when using these ports
Thanks, regards,
Roque
sbilgi Fri, 08/17/2007 - 12:52
  • Silver, 250 points or more
I think The Console port and Management Ethernet ports on the PRP are not subjected to rACL or CoPP policies. The hardware path for these ports does not go through the switch fabric -- it goes directly to the PRP CPU.
