Wireless PCI card and Windows managment.
Aug 13th, 2007
I have a few AIR-PI21AG-A-K9 a/b/g cards in a few PC's. In our shop we let windows manage the cards. One thing I noticed is that under the advanced tab of the wireless properties in Windows you do NOT get all the parameters that you get using the Cisco utility. Is there a way to get more of the parameters in Windows? I am spacficly searching for preferances of network such as "A" over "b".
Thanks!
Overall Rating: 3 (1 ratings)
Alejandro Corte... Wed, 08/15/2007 - 06:44
  • Silver, 250 points or more
unfortunately there the weaknesses of windows, and the advantage of using cisco software is that you can configure more parameters.
cprice2k7 Tue, 08/21/2007 - 06:55
What type of laptops are these? With Dell laptops and the wireless adapter you also get to set band preference if you allow the Dell Wireless Utility to handle the laptop wireless.
