08-13-2007 08:41 PM
hi,
i cannot archive any configuration from my monitored switches. when i do sync, it is in pending state and error message is "telnet:no route to host".when i ping and telnet to those switches and devices from the server,the result is ok.when i check dcmaservice.log and pdshow ConfigMgmt and it shows it is running.but when i looked at the rmegdeamon.xml inside /ciscoworksroot/MDC/etc,the host inside the file is different from the actual host name.so,is it the cause of this configuration archive?so far,i didn't receive any configuration.thanks in advance.
08-13-2007 09:02 PM
Hi Friend,
it seems you changed the hostname and / or ip address recently.
Be sure you did all of the required steps:
There are two paragraphs:
Changing the IP and chaning the hostname. Have a look on them.
Good luck.
Frank
08-13-2007 10:58 PM
thanks for the link.after changing the hostname and restarting the server(not service) then it works and now saving the configuration from devices.
